rear axle stiff
8nstyle
04-19-2006 19:25:11
Did not find this specific subject in the archives. I have a 1949 8N. Axle seals were bad and of course resulted in little to no braking power. Replaced rear axle seals on both sides. After reinstalling both sides there is no end play and the opposite hub/axle rotates in the opposite direction. However, the left side turns quite difficult. Is this normal? I can turn the right side by grabbing the brake drum by hand. But need a wrench on the axle nut to turn the left side. Brakes pads are set loose and are not causing the problem. HELP PLEASE
Dan
04-20-2006 06:37:17
 Re: rear axle stiff in reply to 8nstyle, 04-19-2006 19:25:11
You write: "After reinstalling both sides there is no end play and the opposite hub/axle rotates in the opposite direction." I do not know how the left axle can rotate the opposite direction when you turn the right if you cannot turn the left axle by hand... I will guess that you have your bearing pre-load set too tight. Many times, especially with the paper shims, you can get the bearing pre-load set perfectly, then when you tighten the bolts to spec they are too tight. This is especially true when you are trying to achieve "zero pre-load" and are right at the edge of being too tight and just right. I suggest you remove the left bearing retainer and add one or more shims. You want very little in/out play, but you need some.
Good luck,
Dan
8nstyle
04-20-2006 11:08:17
 Re: rear axle stiff in reply to Dan, 04-20-2006 06:37:17
Thanks Dan, YOu interpreted my poorly written question quite well. I was not sure if the hard turning axle was normal and then didn"t know if that meant adding or removing shims. The thing I don"t understand is why it"s easier to rotate the right axle and the left axle rotates the opposite direction than is is to turn directly on the left axle. It does rotate but needs more torque than would seem normal. I plan to add shim(s)to get as you put it "very little" end play. Thanks again - your response helps make this forum great. I"m learning something from here daily.
