I just got back from taking my first load of things to the machinist -- block, head, crankshaft, and oil pan. I really like this machinist, and I learned a LOT today. But some of the things I learned are sad. Arthur's crankshaft is in much worse shape than I had hoped. And his oil pan has a huge crack in it!!! So far a visual inspection did not reveal anything like that on the block or head, although he thinks the head may have to be planed. (I forget the term for making it re-flattened again at the moment, sorry.) I had been hoping for much better news. Here are a few pictures and the whole sad story. This is the crankshaft. It's real hard to see, but he showed me things I saw clearly once they were pointed out. The middle journal is the one with the white arrow drawn. It has been worn down SO much that the fillets are vanished on each side of it. He showed me what they look like on the other two journals. (I might not have spelled that right, but I mean the deep grooves at each side of the journal, between the "high part" that is like a roller and the cast iron.) Also because it is worn down so much, the oil galley hole in that journal doesn't have a "shoulder" on it like the others do. It just looks like the kind of hole you would make with a paper punch. And it has a crack going out of it on each side, around the roller part-way. He magnafluxed (I got to see that!!!!!) it to see something I did not understand -- I *think* how bad or how extensive or meaningful that crack is. He said he does not do the crankshafts himself, that an older man who owns the shop does them. So he is going to ask him if he thinks this journal can be built up enough to then regrind it. BUT in addition to all this, I don't know if you remember the "blistering" on the bearing for this journal, that I took a picture of yesterday. It turns out it's on the journal "rim" itself as well, and it's not from the rod that went south with the spun bearing. It's from the CLUTCH!!!! He said that when someone pushes and pushes on the clutch too much, it tends to push the whole crankshaft forward. And that has worn this journal "rim" that way. That's why the bearing looked that way. And this is apparently a possibly serious detraction to the chance of successfully building up and regrinding the crankshaft. He said I should start looking for one so I know how much it would cost, so that when the other man comes up with an estimate (if it can be repaired) I will know which way is the better way to go. He added that poor Arthur has been worked pretty hard, and that someone drove him for quite a long time after they really should have stopped. Sigh. Next up -- oil pan. And then two nicer pictures after that.
