Guess what happens when you- ANSWER
old
04-20-2006 19:25:03
Really had hoped for more people giveing there opion oh well. Well I hooked it up pulled the lift lever up, had foot on clutch hand on key just to be safe. Well this little mutt tractor I just built lifted it up, wheels stayed on the gorund and then pulled it the 30 feet I need to pull it to get the MH-30 in the shop. Guess the hyds are very good and it has enough HP do do a little work. And thats with less the and hour on new rings. LOL
Don (NC)
04-21-2006 11:52:39
 Re: Guess what happens when you- ANSWER in reply to old, 04-20-2006 19:25:03
What year is your MH30? I have a 1944 model I'm getting ready to get running again (ran when parked..lol). Has a messy 12 V conversion I'd like to restore to 6 V. The hydraulics work very well and I've been thinking about how to modify it to a Class 1 hitch. Any ideas?
I just got my second 8N working and it's a real workhorse. After the MH30 is a Farmall H that I have dissasembled and hope I can get back together.
Too many projects, so little time.
old
04-21-2006 12:03:44
 Re: Guess what happens when you- ANSWER in reply to Don (NC), 04-21-2006 11:52:39
I think the MH is a 1949, it has a blown engine in it right now and I hope to take tow engines and make one good one from them. You say you have to many projects and not enough time guess you wouldn't want to be me. I have around 30 tractors here and some where around 7-10 of them are ones I'm working on in some way or the other.
hvw
04-21-2006 02:55:16
I didn't get a chance to read your earlier post but I would have predicted it would lift your Massey. My 8N picked up a volkswagen using a boom pole.
FarmerDawn
04-21-2006 12:29:30
 Re: Guess what happens when you- ANSWER in reply to hvw, 04-21-2006 02:55:16
Holy cats!!!!! :-D
B. Jones
04-20-2006 19:32:46
Old, Be very careful with names, you might hurt the little tractors feelings.(GRIN). For 50 years the relief valve goes off before the front end lifts. Is my relief valve weak, I have a new one but have never put it in. By the way , my test is with the tractor standing still in neutral. Should it lift the front wheels????
old
04-20-2006 20:22:19
 Re: Guess what happens when you- ANSWER in reply to B. Jones, 04-20-2006 19:32:46
Well thats a yes no or maybe depending on what your lifting and how far out the weight is. I.E. I have a disc that when It had all the weight on it as it does when useing it on my bigger tractor it will lift the front on an N off the gorund.
