Order Ford 8N Parts Online
8n 12volt upgrade
SBREHM
04-24-2006 12:09:50
I want to upgrade my 8n from 6volt to 12volt. Do I need anything more than the upgrade kit, like new starter, plugs or lights?
Bob
04-24-2006 18:12:30
 Re: 8n 12volt upgrade in reply to SBREHM, 04-24-2006 12:09:50
The 6-Volt starter, spark plugs, breaker points, and condensor are just fine.
Any light bulbs will need to be changed to 12-Volt.
The coil needs to be changed and/or a resistor added. The exact resistor will depend upon whether it has a front-mount or a side-mount distributor, and what coil you are using.
Bob
04-24-2006 18:12:15
Bruce (VA)
04-24-2006 12:16:44
6v starter will be fine, same plugs will work, you will need new headlights. And, I'm just curious, but why would you want to convert it to 12v?
