Jubilee/NAA Valve Cover Gasket
PDB
04-24-2006 13:12:34
Does anyone have any tips on how to keep valve cover gaskets from leaking? What do you use to degrease and clean the mating surfaces? How clean is clean enough? What would I use to straighten the valve cover if it is bent or bowed? (It has a U-shaped channel the gasket sits in) Do I use any gasket sealer or install it dry?
Thanks for any tips.
Dan
04-24-2006 13:21:12
 Re: Jubilee/NAA Valve Cover Gasket in reply to PDB, 04-24-2006 13:12:34
I put mine on dry and it is leak free. Those valve covers get bent up pretty easily, just make sure yours is straight and the "track" the gasket fits into is clean of old gaskets and not mis-shaped. I had to dig a lot of old gasket material out of mine to get it cleaned.
Good luck,
Dan
