3 point hitch won't stay up
Russ Kinch
04-24-2006 14:53:24
I have an NAA where the three point hitch will slowly go down on its own (sometimes not so slowly) after raising it. I have heard there is a check valve that may be leaking, but don't know much about the specifics. Can anyone provide some insight as to where to look and how to correct the problem. I'm assuming it doesn't require extensive tear down/rebuild of the back end.
Thanks
Russ
Jerry/MT
04-24-2006 21:53:56
 Re: 3 point hitch won't stay up in reply to Russ Kinch, 04-24-2006 14:53:24
You probably have a leaking lift cylinder. Get a manual for your tractor and it will tell you how to fix it. Usually you take off an access cover and look up towrd the lift cylinder while it's pressurized and you see a bunch of fluid running down from the cylinder.
