Cheap Replacement Carbs - Any Good?
Alan R
04-25-2006 07:28:31
Anyone tried one of the "Marvel-Schebler design" replacement carbs that are available (seemingly) everywhere (including eBay) for around $120-$170? I have an old carb in need of repairs (no markings on it) but would consider replacing it if the new ones are decent.
Alan R
04-25-2006 11:09:28
 Re: Cheap Replacement Carbs - Any Good? in reply to Alan R, 04-25-2006 07:28:31
Thanks for all of the great advice. I'll come clean and admit that I already put a rebuild kit in this carb several months ago. At the time (just after purchasing the tractor) I thought I could just clean up the carb do a quick tune up with ignition parts etc. and get it running fast. Well, if you've read any of my other posts, you'll know that I ran into an engine rebuild instead and now after many months of sitting idle, I noticed that the choke valve was stuck open. When I attempted to rotate it with the linkage arm that faces the block, the arm broke off of the shaft. I pulled the carb off and looked inside to see that it was a bit rusty looking and that's when I thought about replacing it. However, I think I will try ordering the choke parts first and see where that gets me.
Ray Wilson
04-25-2006 09:10:53
Alan,
I'll post the counterpoint here; I run one of those 'made-in-Taiwan-replacement-carburetors'. Let's call a spade a spade: it's a Chinese knock-off of a Marvel Schebler. Works great, doesn't leak. Cost $99 off eBay. Your milage may vary!
Ray in Sunny PA
Teakettle
04-25-2006 11:19:19
 Re: Cheap Replacement Carbs - Any Good? in reply to Ray Wilson, 04-25-2006 09:10:53
On my Jubilee I have a made-in-USA cast iron MS knockoff that is much less finicky than the rebuilt original one it replaced. It wasn't cheap but it ran perfectly out of the box -- the only thing I note is that it's hard to get it to idle smoothly below about 600rpm, but I'm not one of those how-low-can-you-go idle-
limbo dancers anyway.
dan hill
04-25-2006 14:18:16
 Re: Cheap Replacement Carbs - Any Good? in reply to Teakettle, 04-25-2006 11:19:19
350 rpm is easy
Brian in Colorado
04-25-2006 08:39:39
I would rebuild the one you have. I printed the instructions from this site and spent 15.00 bucks on a gallon of carb cleaner and a rebuild kit. I had more problems with my wife not liking the smell of the carb cleaner than rebuilding the carb!
old
04-25-2006 08:18:08
Well if you feel you just plain have to replace the carb DON'T buy one of the replacement type carbs but buy a good rebuilt one. This site and or valve built has them. Cost is about the same but the real deal is always the best way to go
TheOldHokie
04-25-2006 07:53:43
I second Bruce's recommendation. These are very simple carbs and a quality rebuild will be as good as new for 1/3 the cost. Not to mention "authentic" if you are a purist. See this message if you haven't already:
My Rebuilt Marvel Schebler
TOH
Bruce (VA)
04-25-2006 07:43:37
I do not recall ever seeing a post here regarding 'high quality after market carbs'. I've seen a few complaints, however. Could be that some are fine & folks don't take the time to let us know. But, if it were my carb.....I'd invest the $30-40 for a kit, get a gallon of carb cleaner, print off the great instructions on the left side of this site under research & info, and rebuild it. Or, if you are not inclined to do that, most rebuild shops will do the job for $75-$90. That's about half of what you would pay for the 'replacement' one.
