Carbuerator rebuild and anti-seize...
SCgoatfarmer
04-26-2006 14:10:40
Waiting on parts to replace clutch section on my 1949 Ford 8n. In the mean time working on other projects...
Just finished cleaning carbureator and all the pieces.
Ready to reaasmeble with rebuild kit.
However, should I use anti-seize compounds on the screws locking togehter the top and bottom manifolds?
Definitley shouldnt use on jet seats?
When I disassembled, Teflon tape was used to seal together the elbow joint at the gas intake?
Should I use this when I reassemble?
What about gaskets... should I use RTV compounds?
Hobo,NC
04-26-2006 17:49:34
 Re: Carbuerator rebuild and anti-seize... in reply to SCgoatfarmer, 04-26-2006 14:10:40
RTV and gas don't git along. Teflon tape will not hurt as long as you do not leave enny hang'in to the inside. Tip izz to tape and then a little pipe dope on the tape. remember to apply the tape in the rite direction, or if the fit'in screws to the right then apply the tape to the right. I always say "right on then right on with the tape" then you will not roll the tape up as you install the fit'in, it makes a nice clean leak free job. I see no need fer the anti-seize. If you install the tape on a right hand fit'in to the left the tail end of the tape will wad up then you will be pic'in at it to git the loose strings off but guess what its the same way on the inside and they will break loose and cause the needle valve to stick open. Nutter tip, when ya install the brass elbow I install a fit’in in it the nut off a old gas line of brake line will werk or git one that fits at a parts store not sure of the size, the nut will help reinforce the brass elbow so ya don’t damage the threaded part of the elbow as you thighen it, it will bend E-Zee with out the nut installed. I try and stay to the out side or the ticker part as much as possible. I have a shot adjustable wrench with wide jaws that gives good coverage of the brass elbow. A regular wrench will deform the threaded part of the elbow unless ya stay near the out side or inside of the threaded part. If you have ever had to lay under a big truck and install a hydra booster then you learn this stuff real quick of you will git yer daily dose of brake fluid.
FarmerDawn
04-26-2006 18:10:20
 Re: Carbuerator rebuild and anti-seize... in reply to Hobo,NC, 04-26-2006 17:49:34
"when ya install the brass elbow I install a fit’in in it the nut off a old gas line of brake line will werk or git one that fits at a parts store not sure of the size, the nut will help reinforce the brass elbow so ya don’t damage the threaded part of the elbow as you thighen it, it will bend E-Zee with out the nut installed. I try and stay to the out side or the ticker part as much as possible. I have a shot adjustable wrench with wide jaws that gives good coverage of the brass elbow."
Hobo, do you have a picture that shows this? I am having a hard time understanding exactly how it works. Also, is the type of wrench you're talking about sort of like a crescent wrench? If not, would you mind explaining how it's different so I can see if I have one? Thank you! --Dawn
hobo,nc
04-26-2006 19:01:55
 Re: Carbuerator rebuild and anti-seize... in reply to FarmerDawn, 04-26-2006 18:10:20
Have'in a hard time my self. I ain't as good splain'in things as utters. Will look into the pix its bed time fer me yall will have'ta hold up the fort.
FarmerDawn
04-26-2006 19:06:47
 Re: Carbuerator rebuild and anti-seize... in reply to hobo,nc, 04-26-2006 19:01:55
Sweet dreams! :-)
brian in CO
04-26-2006 15:28:08
I did use some teflon tape on my elbow screen but that was it everything else was just new pasrts and old parts tightened together! No problems yet
old
04-26-2006 14:26:12
NO sealers NO tape NO nothing. Put all parts back in with out any thing on them other then maybe some spray carb cleaner and thats only because if done right they may still be wet from it.
dan hill
04-26-2006 15:47:02
 Re: Carbuerator rebuild and anti-seize... in reply to old, 04-26-2006 14:26:12
I think most carb rebuilds are a waste of time.Most owners introduce new problems.
old
04-26-2006 16:03:42
 Re: Carbuerator rebuild and anti-seize... in reply to dan hill, 04-26-2006 15:47:02
Only if done wrong. Takes time to learn to do them right and even then it can take opening them up 2 or 3 times. I've been doing them for 40 years and I still get them wrong once in a while
Dixon
04-26-2006 23:11:42
 Re: Carbuerator rebuild and anti-seize... in reply to old, 04-26-2006 16:03:42
I agree old 100% and you don"t need airplane tools to do the job just normal tools will do just about 99.9% of the work on any carb or engine.I probaly have rebuilt 5000 carberators and no stuff or special tools
RustyFarmall
04-27-2006 06:18:33
 Re: Carbuerator rebuild and anti-seize... in reply to Dixon, 04-26-2006 23:11:42
I have to agree 100%. You just have to develop a "feel" for it. Some people just naturally have it, others will never have it. Can't explain it any better than that.
