bush hog
roy j
05-01-2006 07:31:56
i need some advice on how to sharpen the blades on
a 5 ft bush hog. how sharp is enough ? what angle so on and so forth . thanks
Bob Harvey
05-01-2006 17:23:56
 Re: bush hog in reply to roy j, 05-01-2006 07:31:56
Only because..... .TURN OFF THE TRACTOR !!! grin.
chris cogburn
05-01-2006 09:57:41
Once agin, Dell's right on target. I was shredding this very weekend, and had to lift the hog to extricate a wad of chain link fence; if I ever see the schmuck who threw the fence out into the middle of the lot, I'm gonna punch him in the nose. But I digress. The 'blades' look more like hammers than axes; they obviously do a lot more smashing than cutting. I hadn't thought of the 'punji stick' problem with sharp blades though. I just know I hit every dang rock and high spot out there; any time spent sharpening would be negated after a couple minutes hogging. And even in their dull state, they seem to cut high grass pretty well.
FYI: yes, I propped the shredder up with a log before getting under it with the pliers and bolt cutters. Took ten minutes of cutting, prying and swearing to get all the fence out.
Happy Tractoring!
c.
Dell (WA)
05-01-2006 08:38:17
Roy..... ...iff'n yer brushhog blades are like mine, leave the "notches". Ya ain't tryin' to "shave" with them. Infact, too sharp is "bad"; why? 'cuz a sharp blade will slice-off small woody plant stems into sharp tire puncturing stubs. Can you say "flat-tire"? Shattered is more desirable. A slightly "rounded" edge (1/16" radius?) is the sharpening goal.
Remember, EYE PROTECTION and block-up yer brushhog before you lay on the ground underneath with yer 4-1/2" angle grinder..... ....Dell, yer self-appointed safety-preacher
StahlMaster
05-01-2006 07:40:23
This link may answer your questions:
