quits and runs bad, help
Pan132
05-03-2006 04:10:06
My tractor runs very poor and keeps quiting when I mow, should I replace the carburator?
JJ
BigMarv1085
05-03-2006 12:14:00
 Re: quits and runs bad, help in reply to Pan132, 05-03-2006 04:10:06
When you 1st start it when the tractor is cold, does it start right up. After its hot and your running it, does it start up easy after stallung out. Does it has a sediment bowl? We need more info.
old
05-03-2006 07:20:13
We need a lot more info to be able to help you. Whats is the tractor, is it front or side mount distubutor?? Do you have good spark?? Whats it do when it quits?? Why do you think its the carb?? A lot of carb problems are really spark problems. Is it 6 volt or 12 volt system?? Etc?
DavidO
05-03-2006 04:37:16
I doubt that you need to replace the carb. Tell us what kind of tractor you have and what you have done to make it run better.
Cargocult
05-03-2006 04:35:38
Not without finding out the reason it quits!! Unless U like buying expensive parts!! Find out just why it quits!! Then U can replace ONLY the items that are needed! Nuff Sed!! CC
