Govenor function
alkolano
05-05-2006 08:11:32
Does all ford 9n's govenor not work while the pto is engaged? It will work when I am plowing, but will NOT work while I am brush-hogging.
Or is my tractor broke?
old
05-05-2006 08:39:56
 Re: Govenor function in reply to alkolano, 05-05-2006 08:11:32
If it works when your plowing it is also working when you brush hog. Whats probably happening is that you have the tractor loaded to the max and it is holding the engine wide open tring to keep it running. What size hog are you useing?? They will just baerly pull a 6 footer so if its a 6 footer or bigger there your problem, or if your pulling it in real heavy stuff
