Order Ford 8N Parts Online
Can't get 8N starter back in
ararboin
05-05-2006 15:51:29
I am stuck with getting the 8N starter all the way back in and the 2 bolts to line up with holes. I've got the starter to within about 1/4 inch out but it refuses to go the rest of the way. Starter also needs to go a bit towards block so bolt holes can line up. Won't budge. What am I doing wrong. Thanks much.
Bruce
Russ SoCal
05-06-2006 08:27:16
 Re: Can't get 8N starter back in in reply to ararboin, 05-05-2006 15:51:29
third party image
Bruce,
Makin' it look like this will help.
Russ
Empennage
05-05-2006 19:18:18
third party image
Did it look like this? Closed..as opposed to spun out and engaged.
Empennage
05-05-2006 20:26:49
 Re: Can't get 8N starter back in in reply to Empennage, 05-05-2006 19:18:18
third party image
Or like this?
ararboin
05-06-2006 06:36:07
 Re: Can't get 8N starter back in in reply to Empennage, 05-05-2006 20:26:49
It's like the bottom picture. Does it have to be closed in order to install??
Empennage
05-06-2006 07:00:45
 Re: Can't get 8N starter back in in reply to ararboin, 05-06-2006 06:36:07
Yes it does, or it wont fit over your ring gear that you see through the hole when the starter is removed.
Was this a new starter? Did you rebuild the old one?
ararboin
05-06-2006 09:23:33
 Re: Can't get 8N starter back in in reply to Empennage, 05-06-2006 07:00:45
"Was this a new starter? Did you rebuild the old one? "
This is the same starter I took out. Just had it tested. Thanks.
Empennage
05-06-2006 12:33:48
 Re: Can't get 8N starter back in in reply to ararboin, 05-06-2006 09:23:33
Have you been able to get it in yet?
ZANE
05-05-2006 18:20:40
On the original N starter drive if it is engaged while it is off the tractor as when one might "test" the starter on the bench by putting power to it to spin it. This spins out the starter gear and it will not go back in until the engine spins it enough to overcome the centrifugal mechanism designed to hole it in till the engine spins it enough to disengage it again.
You can sometimes spin it in the direction of rotation @ clockwise at the gear assembly looking at the washer on the end of the drive with a heavy brush on a bench grinder or with something like a side grinder with a small belt around the starter drive with it held in a vice with the nuts on the two long bolts to hold it securely together while spinning it with the side grinder. Tricky but it will work if you hold your mouth just right! :O)
On some of the starter drives it is impossible to reinstall the starter unless the starter drive is disengaged.
Zane
mn.Chuck
05-05-2006 18:20:20
Did you possibly just put a new drive in? Many of
the improved ratchet 600rpm drives(that eliminate
starter kick out when trying to start)needed to
have the housing ground. As dealers back then we
had a template and saw to modify the housing. Or
did you run the starter and kick the drive out?
makes it harder to get back in. Chuck
Dell (WA)
05-05-2006 17:31:56
ararboin..... ....since the starter motor is only held together by my good looks (grin), many puttta nut on the 8"-long starter bolts to keep'um from falling apart while jigglin' things around durning removal and installation. Did you forget to do the "obvious"?
Otherwize, just jiggle and rotate yer starter motor/armature enuff so the starter bendix gear meshes with the flywheel ringgear.
tip: while you have that 1/4" space between starter motor endplate and flywheel housing, use a wire-brush to "polish" the 2-metals clean for better grounding and faster starter motor turning for eazier starting..... .....Dell
Bob Harvey
05-05-2006 17:12:15
Did you take the nuts OFF ??
ararboin
05-05-2006 19:06:11
 Re: Can't get 8N starter back in in reply to Bob Harvey, 05-05-2006 17:12:15
Yup
Empennage
05-05-2006 17:23:50
Oh yea....the nuts..
Empennage
05-05-2006 16:07:08
Did you replace the drive at the end of the shaft? Was the drive closed when you put it through the hole? Is the starter together and tight? Remember those 2 long bolts that go through the starter hold the whole starter together.
ararboin
05-05-2006 19:04:40
 Re: Can't get 8N starter back in in reply to Empennage, 05-05-2006 16:07:08
"Was the drive closed when you put it through the hole?"
Hmmm, don't know what you mean by closed. But yes I had the bolts on, tho they weren't very tight.
