Order Ford 9N Parts Online
9n Clutch
Ron986
05-08-2006 09:38:09
Guys,Oh, and Girls (just in case)
I know you guys are probably tired of talking about clutch problems, but here's mine, because I need some help.
I used my 9n last fall and let it sit on a graded hillside for the winter. I started it a couple weeks back and low and behold I have no clutch. It won't go into gear unless I shut it off, then the shifter movers freely. Did my clutch burn out? I thought when a clutch wore out the tractor would move even if you forced it into gear. I forced mine into gear while at a low idle and it drove fine. Help, I need help. If I buy a clutch kit does the alignment tool come with it?
Thanks,
RFR
Kelly Jewell (KY)
05-08-2006 10:00:44
 Re: 9n Clutch in reply to Ron986, 05-08-2006 09:38:09
RFR, sounds like your clutch is stuck. Try getting in high gear and holding the brakes. If you need a clutch kit with alighnment tool, email me at jewellco@srctc.com.
