coil test
Peter Hall
05-08-2006 20:01:19
How do you test a 9n front dist coil.I remember in the past using the shock method but have frogotten how to do it.
old
05-09-2006 08:24:07
 Re: coil test in reply to Peter Hall, 05-08-2006 20:01:19
Well to do the painful way you pull the coil and hook it to a battery. You hook the + to the gorund area of the coil and then touch the top post very fast with a wire from the - side of the battery. But its not fun to do.
Tom N MS
05-08-2006 20:19:28
The X-perts on here will tell you there is basically no way to test them without sophisticated equipment that most of us don't have but also Dell recommends taking any old sparkplug(but working plug) and gap it a full 3/16". gtound it to a clean paintfree headbolt or other clean surface and crank it over with the starter, Your spark should jump the 3/16 gap and be a strong BLUE color..Of course glazed/bad points or bad condenser could affect this test too..
