Order Ford 8N Parts Online
ford 8n
ray woodhead
05-09-2006 05:41:39
I have an 8n tractor and I would like to hook a hay rake to it and I need external hyraulics. Is there any way to do it?
soundguy
05-09-2006 06:04:23
 Re: ford 8n in reply to ray woodhead, 05-09-2006 05:41:39
yes you can.. .. and you got 2 options depending on what you need.
If you just need 1 valve to power a single remote.. such as a lift cyl for wheels, and it is a SA circuit power up / gravity down.. then you may be able to get by using the tractors own hyd pump. You chain the upper lift arms to the axle, and then remove the plug from the pressure test port ont he front right side of the bottom plate of the pump.. and use a correct bolt thread fitting to tap pressure to a hyd hose/connector. You use your 3pt lift handle to then control pressure up.. lowering the 3pt handle allows gravity bleedoff o fthe sa cylinder. Caution.. your relief valve will open on your pump when the cyl reaches max travel.. try to keep from doing this much... that is.. lower the lift handle a tad as it gets near max lift. .. say about 1500-1700 psi at about 2.8gpm
Now.. if you need more volume.. and or real remotes for da cyls.. or will need your lift as well.. you need a 'live thang'.. whish is a kit sold by zame sherman.. more or less gives you an engine mounted pump that is tied into your tractors hyd system, and can provide a remote outlet. it makes your tractor lift live.. and as i said.. you can get an optional remote with it.. cost is probably 300-500 depending on what options you get..
Soundguy
