Order Ford 8N Parts Online
Timing on 8n
randy luther
05-08-2001 04:52:36
my tractor was running fine untill it started skipping real bad . i pulled the distributor cap off and the rotor button had distroyed itself so i replaced it and the coil and coil wire ,points and plugs .now i have power on both sides of the coil and at the points(set at .25) BUT CANNOT GET FIRE TO THE PLUG WIRES HAVEN'T CHANGED THEM YET BUT WILL. ANY IDEAS? THANKS IN ADVANCE
Don H
05-08-2001 12:46:11
 Re: timing on 8n in reply to randy luther, 05-08-2001 04:52:36
If I gap my points with a feeler gage my 8N will not start. I have to gap them to where there is just a little daylight between the points. Also check to be sure that the points are not grounded on the distributor. Good Luck!
bg
05-08-2001 05:18:31
How about the cap? Why did the rotor button self-destruct? If you have fire to the points, the "weakest link" has to be in the button or cap.
