filling rear tires
Robert Cook
05-11-2006 13:05:15
anyone got an old manual describing the best way to fill my rear tires for ballast? I know some of the old manuals described a procedure for this.....
Thanks
Ultradog MN
05-11-2006 16:18:17
 Re: filling rear tires in reply to Robert Cook, 05-11-2006 13:05:15
Do you know anyone with a tile saw?
I had to change a fluid filled tire about a year ago.The tire was shot so I took a utility knife and cut a big enough hole in the tire so that I could drop the water pump from my tile saw into the tire. Pumped it in to a 40 gallon trash can that I had rinsed out.
When I had the new tire mounted I just took the tile saw pump, dropped it into the trash can and pushed the hose over the tire stem. I had taken the shrader valve out of the stem. It took about 40 minutes each way to pump the fluid. But I just went in for a cup of coffee and read the latest posts at YTMAG. Worked slick! I just rinsed the pump out after the CaCl and it's still working good today.
old
05-11-2006 15:44:29
Just to make sure you get it drop me an e-mail and I'll send you a copy of a page from a manual that show how, I also answered your post in the ford forum
Jim.UT
05-11-2006 14:20:15
I don't have a manual that explains it but I'll try to explain how I did it.
NAPA sells a special valve that attaches to your tire valve stem. They have two different versions. One is very expensive the other is only about $15. It has a connection for standard garden hose.
Jack up the tire, remove the valve stem core and rotate the tire so that the valve stem is between 10 and 2 o'clock. Attach NAPA valve stem adapter. If you live in a warm climate where it rarely freezes, but connect the garden hose and turn on the water. If you need anti-freeze, then you'll have to choose which type you want. Calcium Chloride gives the most weight and is most commonly used, but is very corrosive. Any leaks will result in rust damage to your rims.
Other options include a product called RimGuard (I think) which is basically beet juice as I understand. Some advocate windshield washer fluid or RV antifreeze. Regular automotive antifreeze could also be used, but usually isn't because of the risk of killing your dog if it leaks out.
Once you have decided what you want to use and in what solution (I used a 50/50 mix of water and RV antifreeze) then you need a way to get it into the tire. I used a hand pump that had a hose bib connection. There are charts in owners manuals telling you how many gallons each tire size will hold. I put half that in the tires and then topped it off with water to get my 50/50 mix.
Before I found this pump, I was intending to use gravity. I had plans to cut a hole in the bottom of a plastic bucket, then attach a hose fitting to the hole. I had visions of standing on a ladder holding a bucket of antifreeze as it drained into the tire. That would have taken a while. I'm glad I found the pump.
