battery drain on 12 volt conversion
RodC
05-11-2006 16:13:13
This 1949 8n is new to me, it has a 12 volt ocnversion, i replaced the 6v coil with a 12v, tractor will run with battery disconnected after a good start and the alternator was excited, main post on alt goes to starter hot side, P2 goes to main post on alt, P1 is exciter on a button, new battery, charged all night, dead in morning or after an hour or so, holds charge if left disconnected, 6v starter, no lights, maybe a short in the starter or solonoid? any help is appreciated guys.
Rod
rodc
05-19-2006 17:33:44
 Re: battery drain on 12 volt conversion in reply to RodC, 05-11-2006 16:13:13
thanks to all with POSITIVE comments, you were a great help, the alternator had a bad diode, casuing hte drain, even tho it charged properly, a rare problem per the alternator shop.
Im not sure what they teach in school these days, when I went the 8N was a popular and late model tractor, I just didnt use one then, so age and wisdom come together with the help of those who have.
the tractor is alive and well.
thanks again for the help and patience RodC
Russ Ehler
05-19-2006 10:16:13
I think those old U's are POS ground. When you put an alternator on them, you change the ground to NEG. You have to be careful or it will burn up the alternator and drain the battery. Switch your ground around. You should not get any sparks hooking up the cables.
RodC
05-12-2006 05:01:17
thanks for the help folks....I'll have the alternator checked.
I didnt know taking the battery cable loose would damage anything, it has worked for years, it allows us with less knowledge to see if the alternator works, right? and to break out our wallets...LOL
with the battery in place, when hooking the charger cables to the battery I get a spark at the post, could this be from the alternator?
thanks again
Bob
05-12-2006 07:55:02
 Re: battery drain on 12 volt conversion in reply to RodC, 05-12-2006 05:01:17
I'm not sure what you mean by "with the battery in place, when hooking the charger cables to the battery I get a spark at the post, could this be from the alternator?".
Be carefull making sparks at the battery terminals so do don't have the battery blow up in your face!
Do you mean you are connecting the charger with it turned on, and it's sparking between the clips and the battery terminals, or do you have a loose terminal, and there are sparks between the terminal and the battery post?
To determine if the alternator is at fault, disconnect ALL wires from it, taping them to prevent shorts, and see of your battery drain problem goes away.
rodc
05-12-2006 14:57:27
 Re: battery drain on 12 volt conversion in reply to Bob, 05-12-2006 07:55:02
I guess I was not too clear, sorry, when hooking hte battery cables up, ground hooked first, when I hook the hot cable I get a spark at the hot post as I connect the cable, this is with the alternator hooked up too. I left the alterantor disconnected and charged the battery, took off the charger and let set overnight with the hot cable disconnected from the battery, battery was strong next morning, have not tried anything else yet, will get back to it this weekend..
thanks
Dell (WA)
05-11-2006 21:02:08
Rod..... ...Yer wired correctly. take yer alternator into an autoparts store for a "free" checkout. Simple, eh? ..... ..respectfully, Dell
Bob
05-11-2006 19:19:16
NEVER pull a battery cable while a charging system with an alternator is operating.
There's a very "good" chance of the resulting voltage spike shorting a diode in the alternator, or damaging the internal regulator.
Guess what... after either a diode or the regulator is damaged, the alternator will drain the battery while shut off!
WHY, oh WHY, do folks insist on removing battery cables while the tractor is running????
souNdguy
05-11-2006 21:09:15
 Re: battery drain on 12 volt conversion in reply to Bob, 05-11-2006 19:19:16
(WHY, oh WHY, do folks insist on removing (battery cables while the tractor is running????
For the same reason why the average person cannot hook up a set of headlamps, or read a simple wire diagram.. anything involving electron flow is like 'deep magic' to the average user. ( so.. what do they teach in school these days? )
Soundguy
Dell (WA)
05-11-2006 21:25:22
 Re: battery drain on 12 volt conversion in reply to souNdguy, 05-11-2006 21:09:15
Sounder..... ..dunnno, I correctly wired my first electrical plug as a Cub Scout when I was 9 in 1947 from the Cub Scout Manual (it had pictures). I also learned how to tie a necktie from same manual and start a bonfire to cook wennies and mushmellers. Mom was more worried about me cuttin' my fingers with her kitchen knife that I used to skin the insulation with..... ..the 10-fingered Dell
souNdguy
05-12-2006 12:38:32
 Re: battery drain on 12 volt conversion in reply to Dell (WA), 05-11-2006 21:25:22
Seems like kids aren't learning much in school these days.. and it isn't the teachers fault either.. it is the school system. My wife is a teacher, and she says that her kindergarten kids can't even write thir name on a piece of paper. I remember whenI was that young.. we hade to be able to write our name and know our address and telephone number when we were school age... That and all the school system seems to want to do is standardized testing.. so that's what the teachers hve to teach.. how to take those tests.. not the real stuff the kids might use during life.. etc. go figure..
Soundguy
old
05-11-2006 16:56:05
Most likely you have a problem with the alternator, or the way it is excited. But I would first take it in and have it checked.
