Order Ford 8N Parts Online
Cannot remove rear wheel hub on 48N
34Ford
05-15-2006 16:11:53
I am in the process of replacing brakes and rear oil seals on my 1948 Ford N. I am at the point of having removed the brake drums but cannot get the wheel hubs to budge. I have stripped the threads on an 8" gar puller. Can I unbolt the bearing retainer and slide the axle out? I would then take this assembly to a machine shop and have the wheel hub pressed off.
Steve IA
05-16-2006 02:38:40
 Re: Cannot remove rear wheel hub on 48N in reply to 34Ford, 05-15-2006 16:11:53
In case the figure 8's don't work,(they didn't for me) yes you can unbolt the the brake ass'y and slide the axle out. Doing this gave me room to give the hub a good whack with the 3# hammer which broke it loose. Or the machine shop will get it off. Good luck. Steve
LumbrJaq NNY
05-15-2006 17:53:16
Yeah, use Joe's method.
I did the same thing and it worked for me.
Loosen'd the big nut and did some figure 8's.
Joe (IN)
05-15-2006 16:23:14
Put your wheels back on and thread the axle nut back on until it is about 1/8" from down against the hub. Take it out in the back 40 and cut some doughnuts and figure 8's with it. The side load leverage against the hub splines will pop it loose. Piece of cake and no work involved.
