I always buy them if I can find them at that price. If they cannot be fixed at a reasonable cost you can triple your money parting them out...every time. However, you missed that opportunity so I'll address you follow up questions. Live pto is very nice, but lots of us get by without it. I use my Ford 850 (bigger than a 9N) to bale hay and I don't have live pto. To me, baling hay would be the most useful reason to have live pto. Buying small, learning as you go and then moving up sounds like a reasonable approach. A 9N or 8N will always have a use on your place even after you've bought a bigger, nicer tractor. The first year live pto became available was in 1955 with the "hundred" series. Ford introduced four different series that year (600, 700, 800, 900) with more than one model available in each series except the 700 series which was only available as a 740. In the other series, live pto was installed on all models that had a 6 in the middle of the model number (660, 860, 960). Live hydraulics was a feature that became available 2 years earlier with the NAA/Golden Jubilee. Some people confuse live hydraulics with live pto, or they just say "live power" without specifically explaining what they mean. If a seller tells you it has "live power", ask more questions to see what exactly he means by that. If his explanation seems to indicate live pto, check the model number. If it doesn't have a 6 in the middle, the seller is telling you stories, or he just doesn't know. ALL Ford tractors have live hydraulics starting in 1953. The N's do not have live hydraulics or live pto.
