NAA stuck in 2 gears
old 9
05-28-2006 08:34:54
How I don't know but I am stuck in First and (I think ) second gears. I got the cover off and tried to pry gears into neutral , rocked tractor ,clutch blocked down. I put a LOT of preasure 4 ft bar even. Next I am going to jack rear see if that helps. Of course is way out back and cannot tow , has front loader ( to get in the way). Would be very hard to split where it is at. Any sugestions? Thanks, Joe
Deri
06-05-2006 16:30:04
 Re: NAA stuck in 2 gears in reply to old 9, 05-28-2006 08:34:54
I have an 8N tractor that is stuck in first and reverse. Did you find a way to fix yours?
old 9
06-05-2006 19:13:21
 Re: NAA stuck in 2 gears in reply to Deri, 06-05-2006 16:30:04
Deri , No luck yet had to put it on the to do list. It looks like I have a broken tooth jamed between the gears. It is locked up tight! My neighbor is bringing his 600 with a boom to move the front end loader, I have moved the flail mower out of the way. The plan is to split it behind the tranny. If your's is not this bad , take the top cover off, look at the gears and shifters, with a small pry try to move everything to neutral , rock tractor ,might help while you are prying. Lots Of Luck and let me know how you come out, joe
do drop in
05-28-2006 09:27:24
stuck 1 3 gear i had to split i had rebuilt trans set bearings preload to tight hung had to take back out ok now
do drop in
05-28-2006 09:03:19
have you had trans out for repair latly? my naa did same thing
old9
05-28-2006 09:19:45
 Re: NAA stuck in 2 gears in reply to do drop in, 05-28-2006 09:03:19
No but it is 53 years old ,had a loader on for many years. I bought it Jan of 05, I think it has been used hard.
