PB, When I got my sickle bar mower (years ago), it did not have the special bracket either. So I made one. If you can find one on another tractor, and buy it, then life is easy. But if your luck runs like mine, then the quickest way to success is to fab up your own. Here is my receipe: Take 2 pieces of 3/8" x 2" flat stock about 6" long and drill a hole at the end that will let the long chain fitted pin go through (probably 7/8" diam holes). The holes need to be located just slightly off center so that the new link pieces will fit tightly in the grooves of the rear end casting. These links need to fit a bit snug to the base of your top link mounting where the approx 12" long pin goes through. Put the 2 links in place and hold temporarily. Cut another piece of the 3/8" flat stock about 4" long so that it can sit on the rear edges of the 2 links, and weld the 3 pieces together like a letter "H". Drill 2 more holes (same size as at the top of the H) near the bottom, approx 3.5" on center from the top holes. This is where you will attach the top link of the SBM with a top link pin. The cross piece of the H gives rigidness to the adapter, without it it's just too floppy. The official adapter even has 2 large set screws that make it more rigid to the rear end casting. What I just described worked well for many years, and enabled me to cut a lot of hay with the 8N SBM. Good Luck! Paul in MN
