BOB / DELL
ron francis tro
05-30-2006 06:42:14
Got this from a Bob Harvey. Did you read it and do you agree? Is that why now that my ceramic ballist resistor is installed it sputters?
ron francis troncatty
05-30-2006 06:44:29
 Re: BOB / DELL in reply to ron francis troncatty, 05-30-2006 06:42:14
forgot to post Bob Harvey's comments..... ....
17:09:26
216.86.96.83
553804
Delete
Just wondering...when you installed the electronic ignition, did you use a 12v coil ?? If you did, you can eliminate the 'infamous' resistor jobby. my $.07 (inflation & exchange)
Bob
05-30-2006 06:47:04
 Re: BOB / DELL in reply to ron francis troncatty, 05-30-2006 06:44:29
Bob Harvey is telling you you can eliminate the factory OEM ballast resistor on the back of the instrument panel by using an aftermarket "12-Volt square-can coil".
Even if you do that, I would still suggest using "Dell's Trick Current Limiting Resistor" of 1/2 Ohm @ 20 Watts.
05-30-2006 06:51:06
 Re: BOB / DELL in reply to Bob, 05-30-2006 06:47:04
well as I said before ..... yesterday I connected up the new ceramic resistor and now the tractor doesn't seem to stall ..... ....just sputters..... ...I'm wondering if its the coil fried or key switch or fuel starvation?
