Ford transmission?
old 9
05-31-2006 19:32:48
Looking for replacement, friend found Ford(?) tranny,but has different shift pattern. Left and up=1st,left and down=2nd, center up =3rd, center down = 4th, Right up = S ( doesn't look like a 5), Right down= R. Could this be from a thousand series? Or? Thanks Joe
DrShadetree
06-01-2006 06:52:38
 Re: Ford transmission? in reply to old 9, 05-31-2006 19:32:48
old9...have you tried looking in the left column under tractor parts + ford + (your model) NAA + drive train.
they have an assortment of components maybe you can use.
DrShadetree
ZANE
06-01-2006 05:59:00
That transmission is a Ferguson tractor transmission. Same as TO 30 or TO 20.
Will fit a Ford at the rear end but not at the front end.
Zane
blitz
06-01-2006 04:33:42
there is a place near Harrisville Pa. that has all kinds of tractors and heavy equip. lots and lots laying around. NE part of the state about 10 east (on rte 8) of the Grove City Outlet Mall that is on 79
Dell (WA)
05-31-2006 19:48:33
old 9..... ....congratulations, you have found a Ferguson tranny with the START button built into the shifter lever. They are NOT interchangeable with Ford trannys. Fergies and Fords look very simular, they oughtta, Harry had all the N-Ford drawings when Henry Ford II told Harry Ferguson his fathers handshake deal was OVER. So Ferguson sued for pattent infringement. The rest is history..... ..Dell
old9
05-31-2006 19:54:06
 Re: Ford transmission? in reply to Dell (WA), 05-31-2006 19:48:33
Dell ' Thanks for your fast reply . looks like I will be tranny hunting tomorrow. My NAA lockedup in two gears and it looks like some chipped teeth, need to get back on road, grass is getting high. thanks Joe
old
05-31-2006 20:59:47
 Re: Ford transmission? in reply to old9, 05-31-2006 19:54:06
I wish you luck on finding one. The only trannys that will work in your NAA is the 1953 Jubilee and the 1954 NAA trannys. A friend a long long time ago found that out when he broke the rear end houseing on his Jubilee.
DennyF
05-31-2006 22:27:33
 Re: Ford transmission? in reply to old, 05-31-2006 20:59:47
Years ago I stopped to see if an ol' boy near Wellsboro, PA with a back yard full of old Fords, might have a ring and pinion for my Jubilee.
Never verified it elsewhere, but he told me the only tranny/ring and pinion that'd work would have to be from the Jubilee series. Said the parts from the 8N/2N/9N series were different. Figured the ol' boy would know, since he'd had a mess of old Fords around there for years. Besides selling parts, he'd rebuild/repaint a few each year, roll 'em out on the front lawn and sell them.
The Jubilee used to go clickety-clack in road gear, so I pulled the plug and qawked into the rearend housing with a penlight while turning a rear wheel. There were several adjacent teeth on the ring gear that were partially chipped.
Never made any noticeable noise in anything but road gear. Guy I sold it to didn't seem to care the gears were chipped.
