Tire Recomendations?
Alan (MS)
06-03-2006 10:05:14
My front tires are shot. They have to be aired up daily. What tires do ya'll recommend? Tube or tubeless? Original or wider car type tires? I read somewhere to go with a 6x16 tire instead of original 4x16, Will they fit my original rims? I mostly use my tractor for dragging my driveway with a boxblade and for bush hoggin. Sometimes I clear brush and push it down the hill. Thanks, Alan
dlplost
06-03-2006 23:05:41
 Re: Tire Recomendations? in reply to Alan (MS), 06-03-2006 10:05:14
Yes the 6.00 x 16 will work, you must use tubes.
I am using 3 rib 6.50 x 16 on my 1950 8N. I have a loader on it and need the wider tires to hold the load. I used to use the old worn out tires off of my old jeep, they were 6.00 x 16.
souNdguy
06-03-2006 21:27:06
If you have the 3x19 rims you are stuck with a 4x19 tire.. or a motorcycle tire.. if you have the 16" rims.. you can get a 6.xx 16 tri rib tire..
Tubes all the way!
Soundguy
lonestarjeff
06-03-2006 19:08:06
You'll need to go back w/ tubes 'cause of the rim design. The narrower tires will steer a little easier.
Jeff
old
06-03-2006 10:32:37
First off unless you make or have some rims made you have to use tubes in those tires. I use truck tires on my 841 but it also has a heavy loader on it and if I didn't it would sink in bad when it was wet out
