Wheel Weight I.D.?
8N'r
06-04-2006 15:25:49
I found some wheel weights for sale (30 miles away) that the seller claims came off of an 8N. He describes them as "section weights" that only work on 6 loop rims. I am familiar with the pie weights. Can somebody post a picture of the "section weight" or tell me if they will fit on an 8N ? Do you know of anyone selling them so I can determine what they cost new? Thanks, Tim
Ultradog MN
06-05-2006 06:00:28
 Re: Wheel Weight I.D.? in reply to 8N'r, 06-04-2006 15:25:49
third party image
8N'r
Those are pretty good weights. If they are like the ones in the photo make SURE you get the little wedges that hold them on. Mine weigh 225 lbs per side. They will fit on the old "top hat" style rims as well as the loop rims. They are one of the few weights that will work on most Fords from the 9N all the way up through the 3 cyl thousand series. I paid $100 plus a 250 mi. round trip to Iowa for mine. I wouldn't sell them now for twice that.
Good luck Jerry
Ultradog MN
06-05-2006 06:11:08
 Pic of them installed in reply to Ultradog MN, 06-05-2006 06:00:28
third party image
nt
old 9
06-05-2006 17:45:50
 Re: Wheel Weight I.D.? in reply to Steve IA, 06-05-2006 03:20:44
Pie weights = $576.00 ,, Inside sets , 450 pounds = $275.00 , 582 pounds = $ 335.00 , Axle weights , 304 pounds = 258.00 . These are 2005 catalog prices. Don't forget SHIPPING.. LOL joe
old 9
06-04-2006 19:12:24
 Re: Wheel Weight I.D.? in reply to old 9, 06-04-2006 19:00:35
Just to add to my other post, on my 9-N I have the axle weights, they add 300 pounds and do not get in the way of changing the tires. joe
8N'r
06-04-2006 17:50:23
Thanks for the replies---I will see if I can find out what they are worth---Tim
J2
06-04-2006 16:35:33
I had these on a Ferguson TO-30. They should fit any tractor with the 28" six loop rims. Each of the 6 sections bolts to one of the six looop bolts. They fit inside the diameter of the rim, usually on the side closest to the tractor, although that depends on how you have wheels mounted. I think that the only problem that you might have is interference with the valve stem, and you won"t know until you try. Some after market rims have them in non-OEM locations. J2
Frank NY
06-04-2006 16:35:16
Are they the 2 piece wights that are "C" shaped. If they are they should go on the inside of the rim but I have a set on the outside on my 640. They add about 300lbs total to the rear axal. Don't know about price I got mine from a 8N that was left for junk. I like them not bad to put on and off the outside of the rim.
Frank
