gahorN
06-05-2006 21:51:16
Re: OT, Snake help in reply to Ole Country Boy, 06-05-2006 10:45:11
How to identify any No. American snake that is poisonous: 1: Has a rattle on it's tail = kill it. (head is slightly triangular also) 2: Has markings across it's back shaped like "dumb-bells" or "barbells" which are tan/brown like dry oak-leaves = copperhead, kill it. (head is oval) 3: Dark-brown or black, nearly solid in color except for lighter-colored belly... opens it's mouth in a threatening manner, showing a very-white inner-mouth = water moccasin/"cottonmouth" - kill it. (this snake is very aggressive and will frequently approach you rather than run from you. Most other snakes will attempt to get away or, if cornered, simply coil up.) 4: Beautifully banded snake with red/yellow/black bands NOT running lengthwise but encircling the body = coral snake (small round head, very timid snake, not aggressive, but poisonous in a more peculiar way. It must attach itself to a small area of your body...like a small finger, etc., and ..chew awile. It does NOT have fangs, but has poisonous saliva which requires long-exposure to create injury. Note: The coral snake (red/yellow bands touching each other) appears very similar to another HARMLESS yet BENEFICIAL "king" snake (red/black bands touching each other separated by a yellow band). King snakes kill other snakes. The helpful rhyme is: red/yellow = kill a fellow.... red/black = friend of Jack. (However coral snakes, while having poisonous saliva, are actually not deadly in the traditional sense. Although their bite can cause severe pain and local tissue damage.) Coral snakes are small snakes, with small round heads, and are not aggressive. I carried one in my pocket when in elementary school all day, once, as a pet. Until the teacher caught me showing it off to other kids. She made me give it to the "science" teacher ...who promptly killed it out of ignorance. No other snake (other than those mentioned above) are harmful in any way. (And one snake, which will attempt to fool you by acting aggressive, is actually quite a joker: The "puff-adder" or "hog-nosed" snake (named for it's distinctive little up-turned nose/nostrils) may actually make a "run" at you to attempt to frighten you away. It sometimes even coils up and "strikes" at you....with it's mouth tightly closed. (Ha!) If you touch it with a stick or attempt to handle it in any way, it's second line of defense is to play "dead" by rolling onto it's back and feigning death. If you roll it back onto it's belly....it'll promptly roll back over onto it's back so it can pretend some more. (grin) Snakes can be very beneficial: They eat mice/rats/insects and some even eat bats. Almost all of them (except cottonmouths) first line of defense is to try to run from you. It's a good idea to get a book or do some research to learn the potentially "harmful" ones (only four of them) so as to overcome your fear and to enjoy the benefits of the rest of them. Knowlege will set you free. Fear thrives on ignorance...whether it be snakes...or politics. ;Þ
