Control and Intake Springs
Rick Hall
06-06-2006 20:37:13
My '47 8N will pick up heavy implements but will not put them back down unless raised clear to the top. I pulled the lift cover. Things looked good. I went ahead and changed to the NAA piston and rings. I pulled the pump and cleaned the control, intake and pump valves and replaced the relief valve. While it is still apart, I would like to replace the control and intake springs as I have seen several posts here indicating that these could be the source of lift problems. Where can you find these springs? My local New Holland dealer could not get them. Thanks.
