1949 8n front mount distributorThreaded new plug wires to tractor. Pulled distributor out. If you are at the front of the tractor looking at the distibutor, they are numbered 1,2, 4, and 3 in a counter clock wise motion starting at the top left. Each of these numbered positions correspond with the cylinder head it needs to go to starting at the front and going back numbered 1, 2, 3, and 4. Correct?... I thought that is the way it goes but as I was replacing them, I could have swore that 4 and 3 were mixed on the distributor. Howevevr, when my tarctor ran it wasnt missing any. I must have just been confused but wanted to hear it from you guys (and girls). Now on the distributor, I kept trying to turn what looked like a Phillips head screw but this is actually the lobe nut(?). Have I screwed anything up by turning this? How do I get the new points to seat through this lobe nut? It just doesnt want to go over it. How do I gap .015 for the new points? Does the copper strip from the coil contact to the point suppose to look that frail? I dont think it can be replaced can it? Alosn off the wall question, when using my pulverizer I have the posiiton control lever down (horizontal). Do I need the PTO engaged for the hydraulics to puch it down or does it automatically push down while the control lever is horizontal?
