Order Ford 8N Parts Online
8n
jason,IN
06-09-2006 18:29:07
has anyone out there ever come across a front dozer blade for these n series. if so how much. also can anyone tell me how hard it is to change the front axle support pin and bushings. plus any tips on doing this. thanks ahead of time for any help.
Jerry (AL)
06-10-2006 04:51:43
 Re: 8n in reply to jason,IN, 06-09-2006 18:29:07
I have a book that shows a bull dozer blade similar to Dell's pic but not the tracks. Also a picture in there of an N with a road grader front on it. The tractor is twice as long as a regular N. The pic is in "Clasic Ford Tractors". It's really got a lot of unique Fords in it.
Dell (WA)
06-09-2006 20:21:34
Jason..... ...ya mean sumptin like this?
third party image
or sumptin like this rear cable raised Dearborn Universal Frame 19-1? third party image
third party image
Many use this much more common and cheaper rear 3-point mounted blade for "dozing".
third party image
Remember there is NO HYDRAULIC DOWN-FORCE. Why? because you will LIFT the rearwheels and loose traction.
As fer yer front axle kingpin, the "archives" at the top of the page of this great N-Board has MANY discussions about it. My advice to you is to "squander" $27 (cheap) for the I&T FO-4 manual which has excellent pictures and instructions on how to replace yer worn frontaxle kingpin. And will also answer alotta yer other questions too. Isn't that amazing? ..... ....respectfully, Dell
Dan
06-09-2006 19:26:01
Jason - ARPS made a front dozier blade for the N Series tractors. It had pivot brackets that I believe mounted to the sides of the tractor so you could raise the blade out front with your rear hydraulic lift arms. They are fairly rare, so when (and IF) you find one it will be pricy. They are more common up North for snow moving.
As far as the front axle kingpin and bushing, they can either be easy or very hard. One tip is to completely remove the front axle and pound the kingpin out from the bask side with a good drift of a good 1 1/4" socket (it fits perfectly) and a BFH. Now, if the bushing is worn to the point of wearing through, you can probably scrape it out fairly easily. However; most are really stuck in and are very tough to remove due to corrosion and dis-similar materials. Some have taken a hack saw blade and cut a slice out length-wise to aid in removal, but be careful not to cut into the actual axle.
Good luck,
Dan
