Well I just got really lucky. I was mowing and hit a tarp covered in some grass and stalled out. I trying to restart and the starter would engage but the engine would not turn over. I rolled it down a hill and tryed to pop-start it with no success. My neighbor towed me with a chain and when I popped the clutch in 3rd the rear wheels spun in opposite directions, but the engine did not move. At this point we both thought the motor was seized and my neighbor suggested that I had perhaps spun a bearing. Being fairly depressed, I had a few beers and Jaegers and went to bed. Sometimes it is better to just let things set when you get too aggravated and then come back to them a little later.The next morning I woke up and decided to take another look at it. I already knew that my flywheel ring gear was chewed up pretty good, so I decided to pull the starter and found that the starter bendix was jammed into the flywheel. I was able to turn the engine, put the starter back in and I pull-started the tractor and finished mowing and cultivated the garden. Here comes the question part of this long post; I know that the starter bendix and flywheel ring is bad. I left the repair manual with the tractor back in WI and I am here in Chicago for a few days and need to order parts. Can I order the bendix part for the starter or will I need the whole starter? Is the ring gear seperate from the flywheel on the 8N or are they one piece? I will no doubt have to split the tractor in half to change out the ring gear. I suppose I should change the clutch and release bearing while I am at it, even though it is OK. I saw one post in the archives that mentions a front transmission seal that should be changed. Is this a good idea? Could someone please suggest a list of parts and what I should change while I have it seperated? I hope not to have to split this tractor again in a long time. I dont have the any other resource at hand at the moment. Splitting the tractor will be a pain but I feel relieved that the motor is OK. Thanks for the help.
