Starter Bendix- new style or original?
Paul Leske
06-11-2006 08:21:44
This site sponsor shows two Starter drives for sale;
Starter Drive - New-starter drive, for 9N, 2N, 8N (1939 to 1952). (Part No: 52-11350C) $36.75 Starter Drive - Original Style For 8N, 2N, 9N (Part No: R2325) $30.30
The price difference does not matter to me. Which is better?
Dell (WA)
06-11-2006 08:48:50
 Re: Starter Bendix- new style or original? in reply to Paul Leske, 06-11-2006 08:21:44
Paul..... ..even the "original style" is NOT original. It needs a new starter retaining pin hole drilled about 1/2" closer to the armature windings.
Me? iff'n I ever haffta replace my starter drive again, its gonnna be the "clutch" style. Why? 'cuz the clutch don't kick-out when the engine koffs during a hard-start situation.
No matter which one you buy, remember ALL starter drives must be squeekie clean. Why? 'cuz oil gumms up and slows down the extension screw and causes starter grinding..... ..Dell
dkocian
07-31-2006 17:40:31
 Re: Starter Bendix- new style or original? in reply to Dell (WA), 06-11-2006 08:48:50
Dell,
Saw your response to Paul on the different style starters for the 8N. I'm trying to figure out how to test the starter to see if it needs to be replaced. I can replace the brushes, etc. but don't know how to tell if the spring and gear assembly (I guess that is the bendix?) is OK or is functioning as it should. How can you tell?
Paul Leske
06-11-2006 09:01:05
Dell,
So which of those two is the "clutch" style? The original?
Thanks.
Paul
Dell (WA)
06-11-2006 09:41:42
 Re: Starter Bendix- new style or original? in reply to Paul Leske, 06-11-2006 09:01:05
Paul..... ..I guess I didn't spell it out clear enuff for you. The original AIN'T clutch.
tip: the "C" stands for "clutch"..... ...respectfully, Dell
happy trails
06-11-2006 13:53:04
 Re: Starter Bendix- new style or original? in reply to Dell (WA), 06-11-2006 09:41:42
since 1950 i have never drilled another hole ag...aint gonna
