Front Spindles
OldeSarge
06-14-2006 14:16:11
Hello Folks, I am hoping someone can help me or at least confirm that I am not totally losing my mind. I have a '41 9N. I am rebuilding the tracotr about 3/4 of the way. I have completely redone the valves, pistons, rings, clutch. I am not getting into the transmission or the hydrolics just yet. I have shopped around for new front spindles, both left and right, and the only spindles I can find ANY where, including on here, have the notch to the inside away from the wheel. The original spindles which is clearly stamped 9N on the spindle buckle
I took off has no keyway and only has the notch hole for the pin and that is facing AWAY from the wheel. Does ano one else have this kind of spindle and can any one tell me where I can possibly find them? The ones listed on this site as well as other places list the part # as 2N3105 and 2N3106. These are NOT the spindles I need or have. THANK YOU in advance.
Ron
Leroy
06-15-2006 04:53:02
 Re: Front Spindles in reply to OldeSarge, 06-14-2006 14:16:11
Those spindles, arms and bolts are no longer avaible, for my 9N I had a machine shpo turn me a new bolt, the 2N used a keyed arm as did the 8N but the location of the key is different so a 8N spindle will not replace one on a 2N but if you replace everything with new spindal and arm then you can put the new unit in any model 9N, 2N, 8N. I own a 41 9N and a 44 2N that Dad bought new in May of 44
Kelly Jewell (KY)
06-14-2006 14:53:09
Sarge, email me jewellco@scrtc.com I can supply you with new spindles. Give me your zip.....thanks, Kelly.
DickTN
06-14-2006 14:37:54
Sounds like you have the 9N3105 spindles which, according to the Master Parts Catalog, are no longer supplied. The suggested replacements are the 2N3105 (right side) and 2N 3106 (left side). Unfortunately, this will require the 2N3130 and 2N3131 steerig arms, right and left hand respectively. Sorry.
