I changed the condensor attachment becasue I couldnt get the tractor to start after the intial run and the FO-4 manual had it connected diifernt. I wanted to be sure it wasnt that. I didnt force the distibutor on. The tangs fit into place. I wasnt sure I didnt turn the tangs 180 degrees howevevr and get it in back wards but it has been said several times that that is not psosible. I looked over the distibuotr, points, gap, rotor, condensor and connections pretty thoroughly before I put the radiator back on. You get a pretty good look from the front. I double and triple examined it probably more. From everything I know and am learning (albneit little) I was sure I had eveything right. That is why I am so confuced now. The first time I opened up the distibutor and changed points and condensor and put back together, she ran like a champ. Then I shut it down and didnt get to run it for a week. When I tried to start her again, she wouldnt fire off. I needed to replace the radiator so I went ahead and broke it down to get another look at my points. When I checked them out the second time, I saw that the points bracket must have moved because when you spun the rotor (unbolted the distibutor to do this) the contacts always touched even on the lobe of the cam. So then I readjusted the gap, locked the points bracket down good, and then changed connection of the condensor for consistancy sake (rediculous I know) Anyway, that is where I am at. Close but no cookie... it has to be something really small like you have suggested that I am overlooking.
