engine speed
paul-mo
06-18-2006 20:07:27
I have a 2n,the problem i have is that the engine does not increase over 600-700 rpm from idle speed to max. speed using the hand throttle. with a load or not. the idle speed is ok. thank you.
Dell (WA)
06-18-2006 20:26:03
 Re: engine speed in reply to paul-mo, 06-18-2006 20:07:27
Paul..... ..It ain'chur carb. this is a 2-part problem.
Disconnect yer governor to carburator spring-loaded throttle rod. (yes, you can do it while the engine is running) Now can you hand-goose yer engine for 2000 max engine rpms? Yes? Itza governor problem. NO? Itza sparkie problem.
Your squarecan frontmount distributor ignition points installation screw needs to be a SHORT (3/16") screw 3/16" is NOT COMMON, 1/4" is TOO LONG and will catch yer centrifical advance weights underneath yer points plate. You need ignition advance to make yer engine speed accellerate, but you need sparkie retard so yer engine starts. There are two #8 screws, the 1/4" condenser hold-down and the 3/16" ignition points hold down. Check-em-out..... ....Dell, yer self-appointed sparkie-meister
