Plowing through roots in a new field
Ed in MO
06-18-2006 20:08:24
I'm trying to plow and disc a new field to plant a food plot. When I cleared the ground there was a lot of small trees all over the field. I bush hogged the smaller ones and cut down the bigger ones. Now my two bottom plow keeps gettin hung up on the roots. Even from the smaller trees. My uncle said to use a disc plow but I can't fine any. TSC has a subsoiler & a middle buster. Will one of those cut through the roots so I can come back with the plow? I'm runnin out of time before planting season is over.
Toby J
06-19-2006 10:28:17
 Re: Plowing through roots in a new field in reply to Ed in MO, 06-18-2006 20:08:24
Depending on how big the roots are, you"ll never be able to plow or subsoil them with the N. Small roots up to about 2" diam. it will handle but even then you"ll hang up some.
I just cleared an acre lot for my new house and I also have a 2N. I used a box blade with chisel teeth set where only the teeth were in the ground. My brother in law with a B2910 Kubota used the same setup and we were able to rip up quite a few of the smaller ones but there are still a lot of big ones that are just under the surface and that"s where they will stay until they rot.
If you want to go to the expense you could get someone with a heavy bush and bog to disc it for you but even then they don"t get a lot of the larger roots.
They used to make a new ground plow that had a knife type coulter mounted on the front of the plow bottom that was sharpened and would cut through a lot of the roots but I doubt you would be able to find one now for your N.
Your best bet is to forget plowing or subsoiling and just disc the heck out of it and get in the best shape you can. That"s what I did on my 8 acres back about 20 years ago. YOu"ll break a disc blade or two probably but you"ll have it in good enough shape to sow your food plot and that"s what you want anyway.
Good luck.
David in Mo
06-19-2006 09:17:29
Forget the plow, disc as best as possible, then plant. It'll take forever to get the roots out with a subsoiler.
Boss Hog
06-19-2006 08:36:26
I think it would be best to get someone with a subsoiler to rip through there. That will bring a lot of the roots up tot he surface where they can be picked up.
I don't think a plow will ever do well in roots.
rob-ks
06-19-2006 04:47:15
Sharpen and adjust the coulters so they cut the roots and trash. That's what they are there for. Or are they there?
There are good instructions in the 9N, 2N, & 8N Ford Operator's Manual.
happy trails
06-19-2006 02:37:06
you do remember the sudden stop from catching roots can cause tra to flip backwards
Ultradog MN
06-18-2006 21:23:18
You have too much plow. Your N is somewhere just over 21 horse at the 3 point. It is as Dell WA
says "a plowing fool" tractor and will pull 2 bottoms in the right soil conditions. But roots and tough old sod aint the right conditions!
Been there done that. Mine wouldn't break 30 yo sod with a 2-14" because I didn't have enough traction. Added wheel weights.
Still couldn't break sod with a 2-14" - had traction but ran out of horsepower.
Realized I had 2 options - More HP or less plow.
Less plow is cheaper than more HP.
Paid dear for a 1-16" plow
1-16" made that poor little 2 N grunt a plenty but it got the job done.
You have way too much plow!
A plow instruction book helped a lot for setting things up. I was trying to turn over about 3 acres. Once I got the 1-16 it still took me an acre to get it to work and my work looked like the worst kind of abject failure.
Finally though either me or the tractor figured things out with the speed and draft and the pitches and angles and that old soil started to lay right. It was really a rewarding experience.
Jerry
