Governor Rebuild
Ralph in TN
06-19-2006 14:35:39
Hi, I am in the process of taking the governor apart to replace the worn parts. I am having trouble knocking out the tapered pin holding the lever arm on the casing. Any suggestions. It is soaking right now, dont know if that will help. Seems like i remember a How To section on one of these sites with details on alot of neat stuff. Where is that site?
Thanks
Tom N MS
06-19-2006 15:41:30
 Re: Governor Rebuild in reply to Ralph in TN, 06-19-2006 14:35:39
Best one I've seen.. Link
Ralph in Tn
06-19-2006 17:24:32
 Re: Governor Rebuild in reply to Tom N MS, 06-19-2006 15:41:30
Thats the site, Thanks Tom
happy trails
06-19-2006 15:24:34
smiths tractor has a ..how to.....
murn-ga
06-19-2006 15:13:04
Ralph, don't know why you would remove the arm unless it was leaking. Try n trac club on how to.
Ralph in TN
06-19-2006 17:26:34
 Re: Governor Rebuild in reply to murn-ga, 06-19-2006 15:13:04
Yes the arm is leaking and real loose. There is so much play in it that I am not getting the full range of motion like it shoudl be. I presume there is a bearing or washer that has worn down inside.
