rebuild a governer
saltydogshep
06-26-2006 03:57:14
im having to rebuild my 9n governer. is there anyone out there who might have any pics or instruction on how to go about this task.. any help would be great. thank you
Bob's Funky Ford
06-26-2006 20:07:05
 Re: rebuild a governer in reply to saltydogshep, 06-26-2006 03:57:14
I took my governer apart. Checked every thing and adjusted to the book. It still did not work. I took it to a shop in Kingman Kansas. They took out 3 shims and adjusted one of the arms. The difference is that they used a tool designed specifically for governer adjustments. It cost me $12 bucks. Let me know if you are having problems and I will give you the address and contact info for Keeling Tractor Co.
dan hill
06-28-2006 03:38:33
 Re: rebuild a governer in reply to Bob's Funky Ford, 06-26-2006 20:07:05
At times it helps to have some one who knows what they are doing to fix a problem.I have fixed electric fence chargers for 50 years.I can usually tell by the sound of the charger when an output transformer has failed.A fellow was trying to diagnose a fence charger problem on a forum.Had some good laughs reading the replies.He finally sent it to the factory for repair.Attempted repairs are a problem, parts are often left out.
ShowMeGuy
06-26-2006 05:23:02
This is the link that I used to rebuild mine. Pretty straight forward with the pics. No fiber washer needed on a early 9N.
ShowMeGuy
ShowMeGuy
06-26-2006 05:21:30
ShowMeGuy
ShowMeGuy
06-26-2006 05:22:37
 Re: rebuild a governer in reply to ShowMeGuy, 06-26-2006 05:21:30
LINK
saltydogshep
06-26-2006 07:28:18
 Re: rebuild a governer in reply to ShowMeGuy, 06-26-2006 05:22:37
show thank u for the site!!!!! !
Westwind
06-26-2006 05:16:56
Salty - Git yerself an I&T FO4 Manual from this site. (<$30.00 Cheap) It has the info you seek as well as excellent instruction on just about ennythang ya might wanna do to yer 9N. Definitely worth the money. HTH
Wes
saltydogshep
06-26-2006 07:27:03
 Re: rebuild a governer in reply to Westwind, 06-26-2006 05:16:56
wes thanks for the info. will be looking into getting that manual.
