8- volt
Paul
01-31-2000 10:08:58
I bought a 8-volt battery to put in my 8-N in place of the 6 My amp meter showes it is dead center or a little in the discharge area when I first started it up ( started like a 12 volt ) I was wanting to know if this is the norm. ----- -Thanks
STUMP PULLER
01-31-2000 17:45:07
 Re: 8- volt in reply to Paul, 01-31-2000 10:08:58
YOUR 8 V WILL BE AN IMPROVEMENT, BUT RESET YOUR REGULATOR TO CHARGE AT 9.8 VOLTS. YOU SHOULD MEASURE THIS WITH A GOOD DIGITAL VOLT METER. THE REGULATORS ARE USUALLY ADJUSTABLE. IF YOUR REG HAS A NO LIKE 8N10505-X WHERE X IS A,B,C ETC. THE RIGHT RELAY IS THE VOLTAGE REGULATOR. ADJUST THE SPRING ARM ON THE BACK OF THE RELAY FOR MORE TENSION.
Claus
01-31-2000 11:32:14
What are you doing about charging the battery? The voltage regulator is set for about 7.5 volts. The Vibrating voltage regulators of today are not made to be adjustable although some may have managed to adjust them by increasing the spring tension on the voltage shunt coil. Happy Motoring
Claus
bg
01-31-2000 11:28:08
More important is the charge rate. Is the generator charging above idle? The 8 volt may tend to wreak havoc with your voltage at the coil unless you use a ballast resistor. A better solution would be to go ahead and do a full 12-volt conversion or optimize(clean, brighten, tighten, rewire)the 6 volt, which was adequate when the tractor was designed.
