Temporary Gas Set-Up
Rush-N
06-27-2006 06:27:48
third party image
After painting, this is one way to Set-Up a Temporary Gas tank to make sure everything is working with your tractor before you put on the always in the way hood and side panels. Also, you can make sure your repairs to your Gas Tank and new Sediment Bowl doesn't leak. A extended Five Dollar Gas Line from Pep Boys to keep the gas tank away while your working at your tractor. Makes life much easier to diagnose problems without taking parts back off. Mark :)
Jerry/MT
06-28-2006 15:52:14
 Re: Temporary Gas Set-Up in reply to Rush-N, 06-27-2006 06:27:48
Heck, I just used a 1 liter pop bottle and a fuel hose and wired it on to the steering wheel. Connected the fuel hose to the carb fuel elbow and a small piece of flared tubing. Worked for me.
I like it...John,PA
06-27-2006 07:26:51
First of all, with all of those great gas station signs, TEXACO, Phillips, Conoco, I envy you.
However, Only problem I have with your set-up is:
How does one reach up to the rafters to put some of those fine products into your gas tank?
I just use a simeple plastic one on a mounting bracket from TROY-BUILT (tm).
Questionable....John,PA
