Points and Condensor
Paul L - Ohio
06-27-2006 17:47:34
I have a 8n with a Front mount dist.
Is the correct way to change to points:
a. Remove the 2 screws on the mounting plate and pull the assy.
b. Remove the two bolts under the dist and pull the whole unit
I read the owners manual and IT manual. The owners manual is kinda vague.
Any other tips would be appreciated.
Paul
klp
06-27-2006 18:31:17
 Re: Points and Condensor in reply to Paul L - Ohio, 06-27-2006 17:47:34
answer b remove whole unit ,replace points and condensor on a table , there is an offset spline on dist so it will only go back one way
