No gas.....
Poot
07-01-2006 19:57:44
Cleaned gas tank, sediment bowl, all screens, & replaced the inline filter. Put in about 3 gal. of fresh gas, & tried to start it.. no go. removed the plug from the bottom of the carb..no gas. Blew back through the gas line & it's clear, sediment bowl fills up, but fuel won't flow through the line. What am I missing?
504-1
07-02-2006 15:37:27
 Re: No gas..... in reply to Poot, 07-01-2006 19:57:44
I just went through this with an 8-N. It had been sitting inside for a year, no gas, the problem was the float had rusted to the hinge pin.I have not put it back togather yet but I am sure it will run fine now.
( Pic ) Ken N Tx
07-02-2006 01:02:10
third party image
souNdguy
07-01-2006 21:13:16
My bets on the stuck float valve... though if the elbox screen is dirty.. it won't help..
Soundguy
roger '40 9n
07-01-2006 20:09:43
Two things come to mind:
1> Carb inlet elbow filter screen clogged.
2> Float valve is sticking -- try tapping on the carb to loosen.
Roger in Michigan
