RoN, The biggest spark will be at the FLAT SPRING, which is the SECONDARY OUTPUT TERMINAL not at the coiled spring, which is the second PRIMARY TERMINAL. You're making it sound difficult... simply mimic the wiring of the coil and distributor. And, since there's no ballast resistor in the circuit, to limit primary current, don't keep pressing the switch until the coil overheats internally, and may be damaged! The trouble is, though, MANY coil problems occur after the engine has run a while, with the combined heat from the current flowing through the coil, and heat fron the engine and radiator causing the coil to "short" internally, and fail, and then work for a while again, after it has cooled. It would be tough to simulate that exact degree of heating, to absolutely verify the coil will work when it's hot. I have a "SUN" coil tester, and recently picked up an "ALLEN" coil tester, which has a "HEAT" function, to safely heat up the coil, and verify it still functions. I haven't had time to mess around with the ALLEN unit yet, though.
