Need help with an ID
Pete76NY
07-03-2006 10:29:14
Guys, found either a 9N or 2N but the serial # doesn't make sense...9NI00847, no dates at all on the axel trumpets, and it doeas have the oval radius rods not I beam style. It also has the original all bakelite steering wheel. Make any sense to anyone?...'cause that serial # makes no sense to me. Thanks, Pete
roger '40 9n
07-03-2006 16:09:56
 Re: Need help with an ID in reply to Pete76NY, 07-03-2006 10:29:14
Yep Serial number 9N100847 would be a 1942 2N engine. The engines are interchangable twixt the 9N/2N/8N series. And many were in the last 67 years.
See the link under "Serial Numbers" on the left.
Remember that the guy who stamped the numbers used the letter "I" for "1" and "b" for "6".
The oval radius rods also indicate a 2N.
According to Smith's tractor site the oval radius rods came in in 1944.
Roger in Michigan
Dan 2N
07-03-2006 12:00:55
Pete, look on the left side of this page at Serial Numbers, the number you gave is for a 1942. HTH
Dan
t model
07-03-2006 10:37:07
check ..smiths tractors
