The generator, and the polarizing thereof have NOTHING to do with starting, at this point. You are NOT supposed to have a high-tension spark at the coil's top terminal, just about 3.5 Volts, if the engine has stopped at a point where the breaker points inside the distributor are CLOSED, or full battery voltage, if they are OPEN. (Assuming this is still an OEM 6-Volt system.) If you DO NOT have the correct voltage to the coil's top terminal, likely there's an ignition switch or wiring problem. Assuming you have the proper voltage to the coil's top terminal, and providing the distributor has been installed correctly, (and it's "guts" have not been pushed out of place by the drive tang being mis-aligned), try stretching the coiled "spring thingy" sticking out of the bottom of the call just a bit. Put the coil back on, making sure the little spring thingy inserts straight down into the distributor body, where it enters a tapered recess in a special brass screw, and completes the electrical circuit between the coil's primary circuit, and the breker points/condensor.
