Oil level dipstick question
Pooh Bear
07-04-2006 22:07:45
If my tractor has sat for more than a hour or so
then before I start the motor I pull the dipstick
and check the oil level. Good habit to have.
My early 1949 8N leaks a little oil. Not much, but a little.
How low on the dipstick can it get before I need to add oil.
third party image
It has 3 lines on it with crosshatching between them.
The top line is the full level and I know not to overfill it.
When it gets below the middle line I pour a quart in it.
I probably go thru one quart every 4 or 5 weeks.
What's the bottom line for.
Is it ok as long as I keep it between the top and bottom lines.
It is not practical to keep it at the full level all the time.
That would be ideal, but I keep watch on it and fill as needed.
Thanks.
Pooh Bear.
Ha Pooh
07-05-2006 16:41:24
 Re: Oil level dipstick question in reply to Pooh Bear, 07-04-2006 22:07:45
You have the wrong dipstick. Calibate the stick to the correct amount of oil, or get the right stick.
Or keep doing what your doing dispite the good abvice Dell and the others gave you, your call.
Pooh Bear
07-05-2006 18:49:33
 Re: Oil level dipstick question in reply to Ha Pooh, 07-05-2006 16:41:24
So far it sounds like a good possibility that
I may have the wrong dipstick.
But before I go buy one I would like to know for sure.
Dell mentioned it should be 12 inches long.
Where should the marks fall along those 12 inches.
Then I could just measure it and see.
Pooh Bear
Sam#3
07-05-2006 06:18:31
Based on years and lots of dipsticks I'd say follow Dell's advice. Calibrate the dipstick to a known amount of oil not the other way around. I've had new engines the 'sticks didn't match the fill.
Dell (WA)
07-04-2006 22:34:54
Pooh..... ...as a general rule, the difference between FULL and 1-Qt low is the difference between the top and bottom lines of yer 12" long engine oildipstick. Its NOT a PRECISION device. Itza close-enuff is good-enuff device.
You doubt? Calibrate it nextime you change oil & filter. Full should be 6-qts. Pour 5-qts in and start the engine to fill the oil filter. Turn engine off after 1-min running and wait 1/2hr for all splashed oil to drain into the oilpan. NOW see where a known 5-qt quantity measures on yer dipp'em-stick. Then add yer final 6th-qt, and checker-again. Simple, eh?
Wannna quess what happens to yer engine oil iff'n ya overfill it? Pumps it out the breather, front and rear crankshaft seals, and yer crankshaft whips the engine oil into mayonnaise. (which is good for polishing little girls pattent leather mary-jane's) but not fer being sucked up by yer oilpump and lubricating yer crankshaft bearings. Itza 5-qt oilpan, (+1-qt in filter) it can tolorate underfill more better..... ..Dell
Pooh Bear
07-04-2006 23:00:19
 Re: Oil level dipstick question in reply to Dell (WA), 07-04-2006 22:34:54
I just changed the oil and filter about a month ago.
I know the IT-F04 manual says 6 quarts of oil.
I'm not certain but I think I only put 5 quarts in it.
And it's been above the middle line all this time.
Probably have to add a quart tomorrow or the next day.
It was rite on the middle line yesterday and was
parked all day today. Probably tomorrow too.
One quart should bring it back up to full.
But as long as I keep it above the middle line I'm safe.
Good to know.
Thanks Dell.
Pooh Bear
uh . . . Dell (WA)
07-04-2006 23:06:09
 Re: Oil level dipstick question in reply to Pooh Bear, 07-04-2006 23:00:19
Pooh..... ..guess I didn't make my self clear enuff. DON'T OVERFILL. Keeper above the bottom line. You just might find that you stop loosing/using oil for the various reasons I enumerated..... ...Dell
Pooh Bear
07-05-2006 00:30:46
 Re: Oil level dipstick question in reply to uh . . . Dell (WA), 07-04-2006 23:06:09
Oh I never fill above the top line.
I usually add 1/2 quart and check it.
Then if it needs more I add more.
It leaks oil the most when it is hot.
Leaks around the front mainseal somewhere.
I can see it drip when I shut down and get off it.
Going to straight 30 weight oil helped a lot.
Moving up to 40w would probably almost stop the leak.
It hardly leaks at all cold that I can tell.
I'll keep watching it and keep it between the lines.
Thanks.
Pooh Bear
Leader
07-05-2006 04:16:01
 Re: Oil level dipstick question in reply to Pooh Bear, 07-05-2006 00:30:46
Pooh... I think what Del is trying to say is.....
If the oil is in the crosshatched area on the dip stick, it is OK. Don't add oil. You may find that it gets down into that area and just stays there for the rest of the season.
With 6 Qts of oil in your tractor, as long as oil shows on the dipstick, you are fine.
