LOADER MOUNTING
Brad the elf
07-07-2006 12:11:10
I have realy enjoyed reading all the info" on this site. Thanks folks.
I have a 2N and a Wagner loader and I need to marry the two together. I"ve read a lot of the message traffic about getting the loader off, now I need to hear from you folks about how to mount it.
The pump drive seems like it will be the problem. I think I have the wrong pulley on the end of the crank. How do I change the pulley?
TheOldHokie
07-07-2006 19:38:59
 Re: LOADER MOUNTING in reply to Brad the elf, 07-07-2006 12:11:10
To replace the pulley you have to remove the front axle support. Here's a couple of pics of my 9N stripped down most of the way. It has a pump hub and mounting plate I'm making for a Dearborn loader temporarily installed.
third party image
The plate's actually for an 8N so it doesn't quite fit right on the 9N but it suffices to check the fit on the new kingpin.
third party image
To replace the pulley you have to remove the axle housing, the crankshaft pulley bolt, and then the pulley "just pulls out" of the timing cover ;-)
HTH,
TOH
Brad the ELF
07-13-2006 04:45:43
 Re: LOADER MOUNTING in reply to TheOldHokie, 07-07-2006 19:38:59
Thanks, I was afraid of that. Looks like I have my work cut out for me. Now to find the time.
