my new project runs!
ron,ar
07-08-2006 10:29:40
The 8N I brought back home last week runs with only 52 dollars invested (for now). It will need lots of work but I have time. It is still 6 volt and all the parts are there but I am going to convert it to 12 volt for now just because I have all the parts laying around to convert it with. My question: I am thinking about removing and saving all the original wiring harness for after I do the body work and re install it all afterward. Is there any need to use any of it for a temporary 12 V conversion? I already installed the 12V dist/coil assembly but will rebuild the 6V assembly and reuse it later. Any ideas on this? Oh, and another question, which wire terminal on a delco alternator is the one to use? The I or the R terminal?
duey
07-08-2006 13:21:05
 Re: my new project runs! in reply to ron,ar, 07-08-2006 10:29:40
Ron, it seems that you can buy a new harness for $15 or thereabouts... it doesn't cover the headlights but not everybody has lights.
Wiring is really pretty basic on these...
duey
Bob
07-08-2006 10:44:00
Here's how to hook up a Delco 10SI alternator. The terminal labels we are concerned with are "1" and "2". There may be other letters above them, which are a carry-over from an older version of this alternator.
Third Party Image
If your alternator does not look like the one in the photo, it may NOT be internally regulated.
An "idiot light" with a #194 bulb can be used in place of the diode.
