It is by no means simpler.. The discreet electronic circuit jump it decades ahead in technology. Try, there are no moving parts.. but you can't discount the 'function' of each discreet component. A fingernail file 'may' get you home if you have a points ignition and you encounter a problem. With an electron ignition.. that same fingernail file will let you file your nails while you wait for a wrecker. Just because there is an electronic replacement to a circuit with mechanical components don't immediatly assume it is simpler. The technology behind a set of points is simple spring, cam and lever.. that's something the greeks came up with. The operation and design of a doped npn/pnp or n-channel, or FET style transistor is a 1950's era brainchild. The technology needed to make a set of points has been available for over a century and longer if the idea had been there.. the technology needed to make a transistor is just hitting the 50 year mark... So I stand by my ascertation that a circuit requiring transistors is not simpler than one requiring a switch ( points )... there is a magnatude of difference. Soundguy
