Order Ford 9N Parts Online
2N or 9N please help identify
RLMiller
07-12-2006 08:45:12
Hello All,
The owner of a Ford tractor is trying to identify if this is a 2N or 9N. When they purchased the tractor ir was supposed to be a 1939 9N. There are serial numbers on the tractor in different places that start with 9N585. Any help would be appreciated. Email me and I will email pictures.
Jim.UT
07-13-2006 09:33:04
 Re: 2N or 9N please help identify in reply to RLMiller, 07-12-2006 08:45:12
Is this the one on ebay that claims to have a s/n on the rear axle? Any numbers on the rear axle will be either part numbers or date codes. As stated below, the ONLY place the serial number is located is on the engine block.
In looking at your auction, I noticed the tractor had oval radius rods. If those are original, then you most certainly have a 2N from 1944 - 1947.
Check the link provided in the responce down below and read that. It will help you figure out what you have.
Bob
07-12-2006 09:50:28
There is only ONE serial mumber, on the engine block, as shown in this link. If you can read the number there, it will identify it, providing the engine has not been swapped in the past.
Third Party Image
